low_suby_wagon Posted December 6, 2005 Share Posted December 6, 2005 Got a 98 LGT 4AT. When the car is cold, and its like 25 degrees or less, when first started is shifts hard from 1st to 2nd. It also seems like it lags or takes longer to shift then when warm. I am not sure if this is normal. Its not taching out or anything when it shifts, but if you drive one a regular basis you when it should shift. I'll be in the car sometimes like, "shift" then a few seconds later it does. The car seems fine any other time, no slipping or anything. Anybody know the cure or have similar problem? Link to comment Share on other sites More sharing options...
legacybg9 Posted December 6, 2005 Share Posted December 6, 2005 there is a temp gage in the trany pan. if the floud is below 32 dregess the computer will hold the gears longer and also not let it in to overdrive. as for slow shifting that is calculated buy the at computer by engine load. and tps inpute. this is also a lurining coumputer. Link to comment Share on other sites More sharing options...
melayout Posted December 6, 2005 Share Posted December 6, 2005 +1, it's normal operation. I keed I keeed Link to comment Share on other sites More sharing options...
low_suby_wagon Posted December 6, 2005 Author Share Posted December 6, 2005 Thanks! I was stressing a new tranny. Link to comment Share on other sites More sharing options...
LGTLover Posted December 6, 2005 Share Posted December 6, 2005 something that may help is disconecting the battery for about 10 seconds (or more) and reconecting it. This erases all memory from the computer about the driver's style. It holds shifts longer for more aggressive drivers. I have a question... I often hear a swooshing sound sorta like splashing water. I assume its the transmission fluid getting squirted through the torque converter, but it didnt do it until i recently got the fluid changed. Not enough fluid? Link to comment Share on other sites More sharing options...
low_suby_wagon Posted December 7, 2005 Author Share Posted December 7, 2005 LGT, thanks so much I tried it and it seems to work well. I also now understand about not letting it shift into OD till warm. I was thinking big bucks. I was like man a new tranny? it only has 80K Link to comment Share on other sites More sharing options...
LGTLover Posted December 7, 2005 Share Posted December 7, 2005 I'm glad! Good luck with everything else! Link to comment Share on other sites More sharing options...
