burtman Posted August 8, 2021 Share Posted August 8, 2021 My daughter has a 2001 Outback/L.L. Bean; 3.0 Engine, 4EAT transmission. At ~151K, I replaced Trans. Duty C Solenoid, seals, clutch plates, several drain/refills on the transmission fluid and the front and rear axle differentials. Generally speaking, the OB transmission has performed well since. Since the work above, there is a very noticeable hard “bump” (hard shift) coming from the transmission (or differential) whenever the accelerator is disengaged/reengaged while “cruising” at highway speeds (60MPH+). I’m not certain if the “bump” existed before the transmission work, but my daughter thinks that it did not exist before. • If accelerator is pressed ever-so-gently while cruising at highway speeds, the bump doesn’t occur. In other words, it can be minimized/eliminated if a conscious effort is made to VERY gently press accelerator while cruising. • “Bump” not noticeable at lower speeds when accelerating/decelerating in low-speed, stop-and-go traffic • I checked the dropping resistor - OK. The condition may be just normal/natural of an aging Suby, but I wanted to check to see if anyone here might have some ideas/advice on what is happening, whether it is a real problem worth concern, and what might be done to fix it. • Could the clutch plate replacement @ 151K be related? • Maybe something associated with the accelerator feedback in the ECU and/or the TCU? • Or is it common and nothing to really worry about? Thanks in advance for any thoughts or advice… Link to comment Share on other sites More sharing options...
