luna7580 Posted July 30, 2021 Share Posted July 30, 2021 (edited) Hi everyone, just joined and wanted to see if anyone else had any similar issues: 2011 Legacy 2.5i Limited approx 143k miles. issue #1-very small "squeak" sound when accelerating, front right side tire only, very random, does not happen all the time. issue #2-the Engine Coolant Warning Temperature Light just started coming on. It blinks red for a bit, then stays solid red then it turns off by itself. I also noticed the AC is not running cold like it did when i got it a week ago. Car sounds fine, its not making any other weird sounds etc. I thought the coolant was low, it was low so I filled it up. Light still came back on, AC still not running cold. i'm looking for a good mechanic in the meantime in my area that deals with subaru Thanks Edited July 30, 2021 by luna7580 Link to comment Share on other sites More sharing options...
NVAKeith Posted August 1, 2021 Share Posted August 1, 2021 …I thought the coolant was low, it was low so I filled it up… Make sure you top off the radiator too when it’s cold. If your radiator is low but your overflow tank is full it could be a sign that you have a leaking head gasket. Link to comment Share on other sites More sharing options...
