tommymac14 Posted June 25, 2021 Share Posted June 25, 2021 Hello all , 05LGT 5mt here. I recently had a misfire in bank 3, after changing the spark and finding no difference i narrowed my misfire down to a not working pigtail connector to the coils, I’m unsure if I should just go with amazon pigtails or if I should try to go to a scrapyard to get that specific part. Thoughts? Apologies I’m new to the car scene. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted June 25, 2021 Share Posted June 25, 2021 Have you found iWire yet? https://www.iwireservices.com/3-pin-plugs Assuming you are referring to the connector plug for the coil. Link to comment Share on other sites More sharing options...
tommymac14 Posted June 25, 2021 Author Share Posted June 25, 2021 Have you found iWire yet? https://www.iwireservices.com/3-pin-plugs Assuming you are referring to the connector plug for the coil. I have not! I am. Thank you so much! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
