cb1232186 Posted June 9, 2021 Share Posted June 9, 2021 Hey! im pretty new here, but recently ive seen some knocks being recorded on my cobb, and i have some logs ive been going through looking for irregularities. I have a 2005 Legacy GT DOHC 2.5l T with 83k on it. previous owner was my boss and he did some fun suspension mods like sway bars, bushings and links, the only engine related mod he did was a lightweight crank. ive put a grimspeed 3" catted downpipe, Catless STI Uppipe, done the timing belt and all its components, along with water pump and thermostat. it truly runs amazingly, so i got my first cobb! it has stage 2 93 OTS map on it currently, but i plan on getting it tuned here soon. but before that happens i wanted to have some of you look over a couple logs and/or help me understand if what im seeing is normal vs. major concern.datalog9.csvdatalog10.csvdatalog11.csv Link to comment Share on other sites More sharing options...
blackobxt Posted June 9, 2021 Share Posted June 9, 2021 Post a learning view. Link to comment Share on other sites More sharing options...
cb1232186 Posted June 9, 2021 Author Share Posted June 9, 2021 Post a learning view. Edit: i should say what do you mean by learning view Link to comment Share on other sites More sharing options...
blackobxt Posted June 9, 2021 Share Posted June 9, 2021 Been a while since I’ve messed with Cobb buy you should have the ability to post a table with learned knock corrections and learned afr Link to comment Share on other sites More sharing options...
cb1232186 Posted June 9, 2021 Author Share Posted June 9, 2021 Been a while since I’ve messed with Cobb buy you should have the ability to post a table with learned knock corrections and learned afr oh okay gotcha. im gonna take a drive tonight and post the logs tonight Link to comment Share on other sites More sharing options...
cb1232186 Posted June 10, 2021 Author Share Posted June 10, 2021 I only saw 1 Knock event that appeared legitimate. maybe i have a bad knock sensor? i tried to organize the table the best i could, highlighting the important areas Link to comment Share on other sites More sharing options...
blackobxt Posted June 10, 2021 Share Posted June 10, 2021 Learned view. Any consistent knock events will be learned and will show populated in a learned knock table. Also learned fuel trims will show which may also point out an issue. An every once in a while knock event won’t populate a learned knock table which would likely show a non issue Link to comment Share on other sites More sharing options...
cb1232186 Posted June 10, 2021 Author Share Posted June 10, 2021 i added 3 screen snips of what appear to be fake knocks, and 1 that appears to be real. let me know what you think because im confused as to why it would do this. gonna change plugs, and make sure there arent any exhaust leaks tomorrow and go for another drive to see if that fixes it Link to comment Share on other sites More sharing options...
cb1232186 Posted June 10, 2021 Author Share Posted June 10, 2021 Learned view. Any consistent knock events will be learned and will show populated in a learned knock table. Also learned fuel trims will show which may also point out an issue. An every once in a while knock event won’t populate a learned knock table which would likely show a non issue and yea, im gonna get romraider set up with my cable and actually use the learned veiw program tommorow as well. seems easier to use than excel Link to comment Share on other sites More sharing options...
cb1232186 Posted June 10, 2021 Author Share Posted June 10, 2021 something happened here with the AF correction, im not sure what, it goes negative, does that mean there was too much fuel? Link to comment Share on other sites More sharing options...
blackobxt Posted June 10, 2021 Share Posted June 10, 2021 I know the access port has its own version. I’m at work and don’t have time to look it up at the moment but I for sure used it when I tuned my sti Link to comment Share on other sites More sharing options...
cb1232186 Posted June 10, 2021 Author Share Posted June 10, 2021 I know the access port has its own version. I’m at work and don’t have time to look it up at the moment but I for sure used it when I tuned my sti is it a computer program? or on the actuall acess port Link to comment Share on other sites More sharing options...
cb1232186 Posted June 10, 2021 Author Share Posted June 10, 2021 I know the access port has its own version. I’m at work and don’t have time to look it up at the moment but I for sure used it when I tuned my sti you mean accesstuner dont you? Link to comment Share on other sites More sharing options...
