Are Spec B Rear strut mounts different?
Yes, the Spec B's have different struts than a GT.
I do believe there is not a left or right side Hat as they are called.
https://www.google.com/search?q=spec+b+bilstein+shocks&rlz=1C1OKWM_enUS906US906&oq=Spec+B+Bi&aqs=chrome.0.0j69i57j0i22i30l3.8835j0j15&sourceid=chrome&ie=UTF-8
Engine Build - Click Here
I'm getting a spec b suspension together and ordering parts.
I'm aware that the shocks and the front top hats are different than the typical Legacy GT.
There question is, are the rear top hats different?
Thanks!
I just went to my local dealers website, the rear top hats are the same part number for my 05 GT wagon and for my 09 Spec B.
Your local dealer should have the same parts list.
SOA parts catalog and local dealers have the same part numbers for GT and SpecB front top hats also.
We know they are different.
Other online sellers of Subaru parts list different part numbers as stated above.
I'm just gonna order 20370AG000 and be done.
I'll report when I take everything apart.
Max, thanks for looking into it!
https://parts.suburbansubaru.com/a/Subaru_2009_Legacy-25L-TURBO-6MT-4WD-GT-Limited-Sedan/_54106_6025245/b13-210-01/.html
The Spec B is the lower number.20320AG01A
The upper number is the same one as for a 2005. I have both cars saved on this site.
I know your in NV but if you call the dealership and tell them you have a Spec B they should be able to tell you the correct number.
I have a great relationship with the Parts guys at my local dealership.
On the Spec B page I see both struts are listed, if you click on them, the $136 one shows its for a normal GT click on the $464 (yellow) one and it says Spec B.
You need the $100 front mount upper for a Spec B.
  • 2 months later...
