Slade-Runner Posted May 20, 2021 Share Posted May 20, 2021 (edited) After installing my downpipe and flashing Cobb Stage 2 OTS map on my 08 Spec B, I noticed it overboosting, I reflashed to low wastegate tune and still was getting some overboost. I was talking with a couple tuners and getting different opinions, varying from needing an external wastegate to the downpipe divider obstructing the internal wastegate. Then I noticed that it was peaking a little over 15psi (Cobb's notes were saying peak should be 16psi +/- .8) and stopped overboosting after about a month of driving. The tuners I talked to said before this that the ECU's learning doesn't affect the boost control and wouldn't be the cause of overboosting. I tried resetting the learning, and it overboosts again. So did the tuners misunderstand how it works or is there another potential issue? I also did a smoke test to check if I have leaks anywhere and found smoke coming out from the plates opposite of the TGV motors on booth housings, is that normal or could there be a bad seal? Stock/Mod list: Stock intake, stock boost control valve, stock bypass valve, Invidia turbo back (lower cat), Grimmspeed TMIC, Perrin turbo inlet hose Edited May 20, 2021 by Slade-Runner Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 20, 2021 Share Posted May 20, 2021 What was the ambient temperature? Elevation is essentially sea level for you? Link to comment Share on other sites More sharing options...
Slade-Runner Posted May 21, 2021 Author Share Posted May 21, 2021 What was the ambient temperature? Elevation is essentially sea level for you? Ambient temp has been all over 50-70, raining some times when cold and dry when hot (Seattle area...), sea level. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 21, 2021 Share Posted May 21, 2021 OK. Exactly how much overboosting have you noticed? Link to comment Share on other sites More sharing options...
Slade-Runner Posted May 21, 2021 Author Share Posted May 21, 2021 OK. Exactly how much overboosting have you noticed? When I had first been running the low wastegate tune, 17-18psi and sometimes 20psi spikes when target is 16psi +/-.8. Now after the reset it spiked upwards of 17psi, but after a few days it hangs around low 15psi sometimes spikes to 16psi. today it maxed out at 13.9psi. Could the wastegate actuator be going bad? Link to comment Share on other sites More sharing options...
Slade-Runner Posted May 26, 2021 Author Share Posted May 26, 2021 bump? Link to comment Share on other sites More sharing options...
