FaderUS Posted May 3, 2021 Share Posted May 3, 2021 I have a 2011 Legacy 2.5 with 130k. I recently had the entire front suspension replaced..Struts (kyb excel-g), 2013 springs, LCA, tophats, right tie rods, and a swaybay upgraded to the larger 2013 outback unit with new swaybar links and bushings. This all oem subaru stuff, except for the struts and swaybar itself (junkyard pull from a car hit in the rear) and the work was done by a Nissan certified mechanic and it was aligned after, with nothing looking off on the alignment report. When I got the car back it was fine for a bit (<100 miles) then started to pop when I turned sharply at low speed, like when parking. I have only noticed it when turning left, and it feels fine while driving and at speed. He diagnosed it to a failed tophat bearing and Subaru warrantied it. I just got it back, and after <20 miles it seems to be returning, though not as loudly as before, so far...any ideas? Link to comment Share on other sites More sharing options...
IJpie Posted May 3, 2021 Share Posted May 3, 2021 Perhaps it is coming from your center differential. Link to comment Share on other sites More sharing options...
FaderUS Posted May 3, 2021 Author Share Posted May 3, 2021 It definitely feels like something in the suspension binding/releasing, and didn't exist before the work was done...what issue with the center diff would cause this sort of an issue? Link to comment Share on other sites More sharing options...
Infosecdad Posted May 3, 2021 Share Posted May 3, 2021 If you drive slow figure 8s and it is popping, a lot of times that is traced back to the CV axles/half shafts. Link to comment Share on other sites More sharing options...
FaderUS Posted May 3, 2021 Author Share Posted May 3, 2021 would axles/half shafts get better for some period of time after everything was torqued then gradually come back? Link to comment Share on other sites More sharing options...
FaderUS Posted May 3, 2021 Author Share Posted May 3, 2021 I have honestly never had a half shaft fail on a Subaru (but I have snapped them on the turbo cars). I may be reading too much into it, but the sound definitely has a sort of sproingy quality like something binding/releasing vs the cv joint click i've heard in other cars. Link to comment Share on other sites More sharing options...
FaderUS Posted May 3, 2021 Author Share Posted May 3, 2021 One thing that I keep coming back to is the used sway bar swap...could anything with the sway and/or endlinks create a popping noise in these conditions? Link to comment Share on other sites More sharing options...
