Geofff Posted May 1, 2021 Share Posted May 1, 2021 So I just picked up an 08 Spec.B from Nashville. I live in PA and will need 1 emissions pass before I am eligible for an exempt sticker. "Vehicles will be exempt from the program if: • the vehicle has been owned for one year and driven less than 5,000 miles in the prior year" I emailed the tuner about his thoughts as the car was pa owned when tuned by him at IAG. I just wanted to gather your thoughts on the best course of action to obtain an emissions sticker. I would prefer to not have to buy a catted exhaust and am worried that even if I do I would have to buy other mods and a tune to pass 1 year of PA emissions. In my county I am required to have the gas cap test and OBD2 Test. Currently no CEL but from my limited research I am concerned about readiness checks. The mods are as follows: 08 Spec.B Base Map Reflashed: Yes PDI: No Code Deletes: tgv and Air pump Engine: IAG Built Management: V3 Fuel: 93 Speed Density/MAF: MAF Map Sensor: OEM Injectors: ID 1000 Fuel Pump: Walbro Intake: Cobb Inlet: Perrin Turbo: 440xt Intercooler: Perrin TMIC Exhaust: Invidia Catless Boost Control: Grimmspeed Spark Plugs: One Step AOS: IAG Comp Clutch: ACT HDSS Thanks! Link to comment Share on other sites More sharing options...
