59ctd Posted April 28, 2021 Share Posted April 28, 2021 For those of you that have replaced the small coolant hoses from the water pump and over to the oil cooler is it necessary to have the manifold off to replace the rear hose out of the back of the oil cooler or is there enough clearance from under and in between the manifold runs? Link to comment Share on other sites More sharing options...
jaylew Posted April 30, 2021 Share Posted April 30, 2021 I replaced mine with the manifold off. Now that isn't to say manifold on can't be done, but it is tight and way easier with manifold off. Also I had the engine out which makes it easier too haha Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
