Yebbey Posted December 3, 2005 Share Posted December 3, 2005 ok, I"m not mechanically inclined I suppose, but I'm not sure I"m suppose to be having such a tough time getting those screws out to get that cover out of the way to get to the wires. Any helpful suggestions?? Link to comment Share on other sites More sharing options...
laz Posted December 3, 2005 Share Posted December 3, 2005 Should be exactly the same. The do not come out all the way, jyst a 1/4 of an inch, and then you pull. that is just on the side ones. The center one just snaps off. You really don't even have to take off the cover, just stick your hand up in the rear left of the cover and you will see the plugs. Should take you 10 minutes with a good light source, and zip tying the plug. X --- Link to comment Share on other sites More sharing options...
mwiener2 Posted December 3, 2005 Share Posted December 3, 2005 moved to interior My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
recuomo Posted December 3, 2005 Share Posted December 3, 2005 Just turn the screw and pull them out and look for the white plug on the left side. You might want to ty-wrap the plug and maybe put a note on it advising service techs that you intentionally pulled it. I had mine re-installed twice when I had my oil changed. They finally got the message when I labeled the plug "Do not touch". Link to comment Share on other sites More sharing options...
Yebbey Posted December 4, 2005 Author Share Posted December 4, 2005 well, i try to pull the screws out, but they won't budge. I don't know...maybe I should ask the dealership to remove it for me for a sec, so I can turn it off. Link to comment Share on other sites More sharing options...
laz Posted December 4, 2005 Share Posted December 4, 2005 Don't push on the screw as you unscrew it. It takes minimun pressure to get them off, and only a fraction of it will come out, not the whole thing. Once the head is out, just pull it from the plastic case. GL X --- Link to comment Share on other sites More sharing options...
Yebbey Posted December 5, 2005 Author Share Posted December 5, 2005 got it, thanks for the replies...i'm just an idiot Link to comment Share on other sites More sharing options...
Vahkil Posted December 6, 2005 Share Posted December 6, 2005 kind of late, but you can practice on the "pop-its" on the engine cover until you figured them out. Link to comment Share on other sites More sharing options...
