JRu17 Posted April 9, 2021 Share Posted April 9, 2021 I know several suspension components on the legacy are interchangeable with the WRX. Does anybody know if the rear trailing arms are? Link to comment Share on other sites More sharing options...
DougKelly20 Posted April 9, 2021 Share Posted April 9, 2021 Excuse my ignorance but are trailing arms the same as lower control arms? If so, the answer is yes, they are the same. I run WRX/BRZ LCAs on my 6th gen. Link to comment Share on other sites More sharing options...
Grnlantern1 Posted April 9, 2021 Share Posted April 9, 2021 I know several suspension components on the legacy are interchangeable with the WRX. Does anybody know if the rear trailing arms are?Yes from 2010 til 2017 I know everything in the Rear is the same.. I didn't research 2018 and Newer.. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
JRu17 Posted April 10, 2021 Author Share Posted April 10, 2021 Excuse my ignorance but are trailing arms the same as lower control arms? If so, the answer is yes, they are the same. I run WRX/BRZ LCAs on my 6th gen. Similar not the same Link to comment Share on other sites More sharing options...
JRu17 Posted April 10, 2021 Author Share Posted April 10, 2021 I started ordering Whiteline suspension bushings and wasnt sure how far I could go. Now when money allows I'll do it all Link to comment Share on other sites More sharing options...
