rejuniwa Posted March 15, 2021 Share Posted March 15, 2021 So I was driving my LegacyGt today, and I noticed my car wasn't pulling as hard as it should be, but only in 4th and 5th gear. When I did a pull from roughly 2500 rpm in 4th, it sat at 8 pounds and revved up slowly, until 4200 when it shot up to target boost(18lb). Gears 1-3 builds boost and pulls as it should. I'm not sure what could be causing this issue, and any help would be great. The car is protuned by a reputable shop with a vf52 and various other mods. I've attached a copy of a 4th gear pull datalog.datalog49.csv Link to comment Share on other sites More sharing options...
dwmccauley01 Posted March 15, 2021 Share Posted March 15, 2021 So I was driving my LegacyGt today, and I noticed my car wasn't pulling as hard as it should be, but only in 4th and 5th gear. When I did a pull from roughly 2500 rpm in 4th, it sat at 8 pounds and revved up slowly, until 4200 when it shot up to target boost(18lb). Gears 1-3 builds boost and pulls as it should. I'm not sure what could be causing this issue, and any help would be great. The car is protuned by a reputable shop with a vf52 and various other mods. I've attached a copy of a 4th gear pull datalog.Your wastegate is at 0 until you hit 4k. Hard to say what it's doing without seeing the table but for whatever reason it's running wastegate pressure until 4k. Sent from my SM-G970U using Tapatalk Link to comment Share on other sites More sharing options...
BrandonspecB Posted March 15, 2021 Share Posted March 15, 2021 You need to let your tuner know. Link to comment Share on other sites More sharing options...
