902Legacy Posted March 11, 2021 Share Posted March 11, 2021 Is there any way I can easily diagnose rod knock? I’m hearing a slight possibly knocking sound and a little bit of a squeal. After watching some YouTube vids I’m really starting to worry it might be the start of something worse. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted March 11, 2021 Share Posted March 11, 2021 You should check your oil to see if there are bits of metal in it. Cut open the oil filter. My car had very pronounced knocking at the very end of its first engine's life. Low oil level would also help diagnose this as you may have run the car low on oil. Link to comment Share on other sites More sharing options...
stewdogg Posted March 12, 2021 Share Posted March 12, 2021 In addition to the above you could use a mechanics stethoscope or long screwdriver to pinpoint where the sound is the loudest in the engine. Go to where you hear the noise the loudest in the engine bay and stick the tip of your scope or screwdriver on the metal of the block and heads and notice where the sound is the loudest. How are you hearing the knock? Is it always there or only under load or a specific RPM range? I lost a wrist pin in mine. It started with a small knock on start up and got worse from there. I nursed it till it just stopped running and then dove in deep with the rebuild. Link to comment Share on other sites More sharing options...
DrD123 Posted March 12, 2021 Share Posted March 12, 2021 A spun bearing isn't going to squeal - also, there are other things that can sound similar to rod knock that aren't (timing belt tensioner being the primary example) - definitely have it checked if you don't know what to look for. If you drain the oil and there are metal bits in it, then you can be pretty certain it's a spun bearing. (when it's really bad, it makes a characteristic tok-tok-tok sort of sound - go on youtube and there are a bunch of videos) - how many miles on the engine? is this a GT? Link to comment Share on other sites More sharing options...
phillbert Posted March 13, 2021 Share Posted March 13, 2021 With my past Subaru, it turned out the issue was the timing belt tensioner failing. It makes a know almost identical to rod knock at higher rpms. Take a look at this and see if its similar. Hoping this is the issue. Link to comment Share on other sites More sharing options...
