DwntwnDanny Posted March 10, 2021 Share Posted March 10, 2021 (edited) Hey Guys! Wondering anyone has come upon with this issue. I have Tactrix Cable 1.3v and I've been trying to connect EcuFlash with my ECU so I can download the Rom and look into the tune to see what all the parameters are. The issue I'm having is that the EcuFlash fails to connect to the Ecu after I turn the ignition on and hit send the connection to the ECU. I've attached the logs files the program made to show what is happening. I've redirected the directory files to where there should be in hopes that was my issue but I was wrong. In reference to this forum post. https://forums.nasioc.com/forums/showthread.php?t=1561824 I tried to uninstall the program, Romraider and any can-bus software I've had incase that was causing any issues. Reinstalled Ecuflash and did what I did above and no luck. I reinstalled romraider/logger and use the logger to verify that the connection was good, and it was. So, I'm a bit stumped and don't know how to move forward from here. Something to mention is that the previous owner did flash the car using romraider before and did his own mapping and such. So I don't know if that could be a issue or not. Please let me know of any suggestions or ideas of what to do. Please note: I did have my green connector connected together throughout the whole process, and everytime I try allow EcuFlash to connect to the ECU, my coolant temp. gauge gets maxed out, and Error HC pops up. Don't know what that means, but please do let me know!Logs.pdf Edited March 10, 2021 by DwntwnDanny Attachments files didn't work at first. Link to comment Share on other sites More sharing options...
