64rcs Posted February 16, 2021 Share Posted February 16, 2021 I have an 02 Legacy GT with a froze up 5 speed transmission. Finding a used manual from a GT has proved quite difficult. A salvage yard has a 2003 GT with a 5 speed, but is a high/low(dual range) transmission. Anyone know if this will work? I know there is a ratio difference between outback and legacy GT transmissions. I don't have enough motivation to put a outback transmission in and switch the rear diff to match. Link to comment Share on other sites More sharing options...
xrayspecs Posted February 17, 2021 Share Posted February 17, 2021 not sure which rear diff you have, you would need to find the final drive on the below and match it to your rear diff ratio. some information on decoding your current transmission tag to find your Final drive, and how to see what the final drive on the transmission you are looking at. http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart https://forums.nasioc.com/forums/showthread.php?t=2173258 Link to comment Share on other sites More sharing options...
