08SubieLegacy Posted December 5, 2020 Share Posted December 5, 2020 My car won't go over 20mph. It's difficult to even get to 20 mph. I thought my transmission went out, so I replaced it, and with the new transmission, I have the same problem. I had the throttle body off, and noticed the inside of the intake had a pool of oil in it. I thought the problem may have been the PCV valve, so I removed it, it was all gunked up. No parts stores in the area had another one, so I cleaned the old one and reinstalled it. My car has been burning oil, so it's coming through the intake. How is it getting in the intake though? Could the oil have fouled a sensor, causing my car to not go above 20mph? Car is a 2008 Legacy, 2.5 naturally aspirated engine. Automatic transmission. Sent from my SM-G981U using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted December 5, 2020 Share Posted December 5, 2020 (edited) I have oil pooled in my intake manifold too, I think it comes up through the pcv valve and accumulates. I don't think that's the source of your problem though. Have you had a check engine light, or any trouble codes? I would imagine there must be some codes stored if the car won't go over 20 Edited December 5, 2020 by apexi added a few random pics I took a few years ago. Link to comment Share on other sites More sharing options...
Pleides Posted December 6, 2020 Share Posted December 6, 2020 Clean your MAF sensor and replace your air intake filter and see if the problem goes away? Surely you have a CEL? Link to comment Share on other sites More sharing options...
08SubieLegacy Posted December 8, 2020 Author Share Posted December 8, 2020 I don't have any check engine lights. Weird. I wish I did, might actually tell me something. Will clean the MAF and report back. Sent from my SM-G981U using Tapatalk Link to comment Share on other sites More sharing options...
blackobxt Posted December 8, 2020 Share Posted December 8, 2020 Does the car rev normally in neutral? Can you rev all the way through the rpm ranges? Link to comment Share on other sites More sharing options...
08SubieLegacy Posted December 8, 2020 Author Share Posted December 8, 2020 Cleaned the MAF, seems to idle better. Drivability still sucks though. I can rev up to 3500 rpm in neutral. Sent from my SM-G981U using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted December 8, 2020 Share Posted December 8, 2020 Clogged catalytic converter? Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 8, 2020 Share Posted December 8, 2020 ^^^^^My thoughts exactly. Burning a lot of oil fouled and clogged the cat. Probably trashed the front O2 as well. Link to comment Share on other sites More sharing options...
blackobxt Posted December 9, 2020 Share Posted December 9, 2020 Two tests, 1 disconnect maf and try to rev engine 2 pull the pre-cat o2 sensors and see if it runs better AND OR if you have an infrared temp gun, test the temps pre and post cat. A normally functioning cat will have the exhaust coming out of the converter higher than going in. A failed cat will show the exhaust before the cat considerably hotter Link to comment Share on other sites More sharing options...
blackobxt Posted December 9, 2020 Share Posted December 9, 2020 I’d try the second tests first Link to comment Share on other sites More sharing options...
08SubieLegacy Posted December 12, 2020 Author Share Posted December 12, 2020 I used a can of seafoam on the intake, the smoke out the tailpipe cleared up after that. The car revs normally up to 4.5k if moving, it doesn't want to shift gears though. Had a mechanic look at the car today, they think the people I got the transmission from gave me a bad transmission. I'm working on getting a refund for the transmission. Sent from my SM-G981U using Tapatalk Link to comment Share on other sites More sharing options...
blackobxt Posted December 12, 2020 Share Posted December 12, 2020 That wouldn’t prevent the car from revving in neutral Link to comment Share on other sites More sharing options...
Pleides Posted December 14, 2020 Share Posted December 14, 2020 I used a can of seafoam on the intake, the smoke out the tailpipe cleared up after that. The car revs normally up to 4.5k if moving, it doesn't want to shift gears though. Had a mechanic look at the car today, they think the people I got the transmission from gave me a bad transmission. I'm working on getting a refund for the transmission. Sent from my SM-G981U using Tapatalk Seafoam causes smoke out the intake. That's normal. That's just Seafoam blowing out the exhaust. The issues you listed are not a transmission issue almost certainly. You should be able to rev the car out in neutral. Link to comment Share on other sites More sharing options...
08SubieLegacy Posted December 14, 2020 Author Share Posted December 14, 2020 There's a good bit of debris on the transmission fluid dipstick. Pretty sure I have a transmission problem. Sent from my SM-G981U using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted December 15, 2020 Share Posted December 15, 2020 There's a good bit of debris on the transmission fluid dipstick. Pretty sure I have a transmission problem. Sent from my SM-G981U using Tapatalk You'd still be able to rev out in neutral and not have a bunch of oil in your intake. I'm gonna give you the benefit of the doubt and say sure, you got a bad transmission, but this car seems to not really be worth your time. Link to comment Share on other sites More sharing options...
blackobxt Posted December 15, 2020 Share Posted December 15, 2020 Nobody is saying you don’t have a bad transmission, everyone is telling you that the transmission has nothing to do with your other problems Link to comment Share on other sites More sharing options...
