Chief_Wiggum Posted November 29, 2005 Share Posted November 29, 2005 Been running around on my new coilover setup (Cusco Zero-2s) for a couple weeks now. I'm noticing a rattle from the front right over just about every bump I go over. Other 3 corners are fine. Re-checked the top hat bolts and all are fine, camber bolts are tight as well. It sounds almost like the strut shaft nut is loose, but I can't tighten it without spinning the strut shaft. The marks are still aligned, but I'd like to try and tighten it to spec, any ideas? Link to comment Share on other sites More sharing options...
froggert Posted November 29, 2005 Share Posted November 29, 2005 impact wrench? Link to comment Share on other sites More sharing options...
SnoDork Posted November 29, 2005 Share Posted November 29, 2005 Been running around on my new coilover setup (Cusco Zero-2s)...It sounds almost like the strut shaft nut is loose, but I can't tighten it without spinning the strut shaft. The marks are still aligned, but I'd like to try and tighten it to spec, any ideas? PM on the way... ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
SWortham Posted November 29, 2005 Share Posted November 29, 2005 I had this same problem with my car recently. I used an impact wrench to get it started, and then used a torque wrench to torque it to spec. Another method would be to get a tool to hold the shaft in place while you tighten the nut. I wouldn't use just anything 'cause you wouldn't want to scratch that shaft, but I think they make a special tool for that sort of thing. Link to comment Share on other sites More sharing options...
Chief_Wiggum Posted December 1, 2005 Author Share Posted December 1, 2005 Well, I think I figured it out. I pulled the strut to tighten the top nut. The upper spring perch must be keyed to the shaft. You can use a spanner wrench to hold the shaft while you torque it down. The nut was just a hair under the spec. Tightened it up and the noise is greatly reduced. Now at least both sides sound the same Link to comment Share on other sites More sharing options...
