RustyRuu Posted October 30, 2020 Share Posted October 30, 2020 (edited) Is it possible? I'm in the salvage business and ive had no luck, which says something about the chip key system. Others are a little easier to pull off. Tried pulling the ignition cylinder, arching the starter and spraying the intake with starter fluid and no go. I know this could be a touchy subject so let me know either in a PM or here. Edited October 30, 2020 by RustyRuu Link to comment Share on other sites More sharing options...
Infosecdad Posted October 30, 2020 Share Posted October 30, 2020 What year and model? The 05+ GT has an immobilizer w/ chip in key. I think the SE was a year behind. http://www.cars101.com/subaru/keyless.html#immobilizer%20keys Link to comment Share on other sites More sharing options...
RustyRuu Posted October 30, 2020 Author Share Posted October 30, 2020 Is an 05 currently, couldnt get an 11 to start either both legacys. I am aware of an immobilizer but curious if there is a way around it? Link to comment Share on other sites More sharing options...
blackobxt Posted October 30, 2020 Share Posted October 30, 2020 Romote start installer/ professional Hotwire guy here, pretty sure it’s not possible as a few things happen when the imobilizer kicks in and I believe one of them is cutting ignition on the coils Link to comment Share on other sites More sharing options...
leetdrv Posted October 31, 2020 Share Posted October 31, 2020 The engine computer will not turn the engine on without a chipped key present. You can tow the car to the dealer to program a key Or install a matching set (key+ECU+BIU+gauge cluster) from another car Link to comment Share on other sites More sharing options...
RustyRuu Posted October 31, 2020 Author Share Posted October 31, 2020 Thank you for all the input. Just curious what locksmiths do when they come to make a key for it, or when you go get a second chip key made. They pretty much can do it at any hardware store. Is there a code in the vin or something that might hint at what key will work with the immobilizer? Link to comment Share on other sites More sharing options...
Infosecdad Posted October 31, 2020 Share Posted October 31, 2020 Thank you for all the input. Just curious what locksmiths do when they come to make a key for it, or when you go get a second chip key made. They pretty much can do it at any hardware store. Is there a code in the vin or something that might hint at what key will work with the immobilizer? Not the immobilizer keys. The dealer can look up the VIN in their system and code the chip. But when I tried going to one of the newer key/fob combos the local locksmith told me they can only cut the key, they can't deal with the immobilizer chip. (which was fine for me, I cut the old chip out of my other key and used it) Maybe there is one that can, but as far as I know, it's a dealer only thing. Link to comment Share on other sites More sharing options...
leetdrv Posted November 1, 2020 Share Posted November 1, 2020 The dealer will register the new key rfid tag with the immobilizer. This requires dealer tools. The VIN is stored in the ECU only, not in the immobilizer or key. Locksmith can only help you if you have a key or at least the chip portion of the key. They clone the rfid chip. Link to comment Share on other sites More sharing options...
leetdrv Posted November 1, 2020 Share Posted November 1, 2020 there is no unique code. the key, cluster, ECU, BIU are sync'd. cluster, ECU, BIU have eprom chip where the data is stored and the key has a RFID chip. Link to comment Share on other sites More sharing options...
leetdrv Posted November 1, 2020 Share Posted November 1, 2020 if your car has a manual transmission and you feel adventurous, you can install a '04 STI ECU and wiring harness, there is no immobilizer... Link to comment Share on other sites More sharing options...
RustyRuu Posted November 2, 2020 Author Share Posted November 2, 2020 Again thank you to this community. Like I said I'm in the salvage business, it would be nice to see an engine run before selling it, compression tests are just not enough sometimes. It's too much work to send it to the dealer to get a key than to get a motor sent back. I was just thinking there was a hack way to get these running. I just want to sell reliable shit and take chance out of the whole thing Link to comment Share on other sites More sharing options...
