cal71919 Posted October 28, 2020 Share Posted October 28, 2020 (edited) Year, Make and Model: 2006 Legacy GT Wagon Color: BSM Miles: 258ish Transmission: 5EAT with Hexmods VIN: 4S3BP676364303258 Located in Houston, Texas Price: $4,500 Motor / Drivetrain: CP forged pistons Stock connecting rods and other internals Stock rebuilt heads GrimmSpeed crosspipe, gasked matched ported oem manifolds GrimmSpeed Uppipe Ceramic Coated. Invidia catless downpipe Stock cat back exhaust( Invidia axle back not installed yet) SPT turbo heat shield BNR 18g turbo Aftermarket turbo inlet(not installed yet) DW 740 Injectors DW 65wc Fuel Pump GrimmSpeed EBCS Turkeylords EBSC fittings Fast Motorsports Black coated FMIC and piping Forge BOV 100% recirc PLX SM-AFR v3 with custom Romraider build to log Open Source Tune by Cyro STI dogbone mount Group n*motor mounts Aluminum radiator Hex Mod Valvebody Upgrade Mishimoto transmission cooler w/fan and thermostat Suspension: Front: Koni inserts H&R Springs Whiteline front LCA bushings Whiteline front LCA anti lift kit (rear bushings) Whiteline*ball*joints Whiteline tie rod ends Whiteline Front 22mm adjustable sway bar and bushings Whiteline power*steering*rack bushings Rear: Whiteline KTA124 Whiteline W63394 Whiteline 20mm adjustable sway bar and bushings Koni struts H&R Springs Spec B Alum. Trailing Arms Spec B Alum. Lateral Links AVO Sway bar reinforcements 2012 18" Legacy wheels 215/45/18 Continental Extreme Contact(less than 5k miles) Interior: JDM double din hvac console Pioneer AVIC navi / headunit Installed: VBG-1 SM-AFR v3 Moving on to another project and would like it to go to someone who will drive and appreciate it. Front driver side strut is clunking but strut isn't leaking and still handles very well. Some rust along lower edge of drivers door. Had headgaskets done about 3k miles ago, runs very well. Also has new a/c compressor, new condenser, new rotors and brake pads. Edited November 2, 2020 by cal71919 Link to comment Share on other sites More sharing options...
cal71919 Posted October 28, 2020 Author Share Posted October 28, 2020 (edited) May entertain trade offers but leaning towards a cash sell. Edited October 30, 2020 by cal71919 Adding pictures Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 30, 2020 Share Posted October 30, 2020 Attach your pictures. We do not allow linking out to pictures. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
cal71919 Posted November 9, 2020 Author Share Posted November 9, 2020 ***sold*** Link to comment Share on other sites More sharing options...
