Rear brake pads asymmetrical on 2013 Legacy 3.6R?
I ordered new pads and rotors for the Legacy.
Did the front a few days ago and when I got to the rear I ran into an unfortunate surprise.
Only one out of the four pads in the Akebono kit that I ordered have a clip riveted to the rear of the pad.
I double checked the car and both the inner rear pads in the have a clip riveted to the pad. I got the car with only 30k so I'm quite sure those are the original pads.
So I contacted the seller expecting the box was just loaded incorrectly. They said this is by design and all the kits are made like this. I looked at a couple other kits and sure enough only one out of the four pads has a clip.
I am really perplexed by this.
I can't imagine why any vehicle would need a clip only on one side. Did Subaru update this at some point and only require a clip on one side?
Apologies if this has been going over, I did a search and couldn't find anything.
Sent from my Pixel 3a XL using Tapatalk
Okay I think I found the answer.
It seems these are wear indicators and not necessary for holding the brake pad in place, which is what I thought.
It seems a lot of aftermarket manufacturers have opted to only include one to save cost, since if one is that worn they both need to be replaced anyway.
I put Akebono pads on my car last time. I seem to recall that there was a squealer-clip only on one pad rear pad. Not sure about the fronts. The Wagner OEX pads I put on my wife’s Forester last weekend had them on both sides of the front and back pads. On all my other cars - Subarus and otherwise - those clips are hit or miss. Only my old BMW and Audi consistently didn’t have them, though I suspect it’s because those have electronic wear sensors instead.
This would seem to support your notion that each manufacturer does what they want. [emoji2369]
