Marvick08GT Posted August 16, 2020 Share Posted August 16, 2020 (edited) My buddy has a set of fans from his front clip he doesn't need (EJ207). I want to use them, but they don't look like the same blades.(cooling is 4 instead of 5, and condensor is 5 instead of 7) Is there any issue with using these on my spec B? Shrouds and electrical connectors are identical (2 wire) but most online sources say it should be a 4 wire connector? And show the same fan blades as I have (5 and 7) All help appreciated, thanks for the info! Edited August 16, 2020 by Marvick08GT Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 17, 2020 Author Share Posted August 17, 2020 Looking at some of the aftermarket fans available for the 2.5t it seems that some use the same 4 and 5 blade for the turbo and nonturbo models. Hopefully someone knows more than me, not sure how the blade design might alter flow, but from reading it is suggested that more blades is quieter, with less flow. Link to comment Share on other sites More sharing options...
