AVGxp Posted August 12, 2020 Share Posted August 12, 2020 I recently bought my car and of course the light didn't come on until I drove it off the lot, it came on halfway on my drive home and then it was off the next time I turned on, and it's been turning on and off at random. How can I troubleshoot it? Do I have to take it into the dealer? I tried to pull codes with an odb2 reader and the torque app with no luck. The car is not being used right now but I want to have it sorted by the time I start driving it in late October. Link to comment Share on other sites More sharing options...
apexi Posted August 12, 2020 Share Posted August 12, 2020 Probably a cracked solder joint, common issue. Just heat up the solder with a soldering iron to fix it. https://legacygt.com/forums/showpost.php?p=4278790&postcount=60 https://legacygt.com/forums/showpost.php?p=4643620&postcount=117 https://legacygt.com/forums/showpost.php?p=5339079&postcount=188 Link to comment Share on other sites More sharing options...
AVGxp Posted August 12, 2020 Author Share Posted August 12, 2020 Probably a cracked solder joint, common issue. Just heat up the solder with a soldering iron to fix it. https://legacygt.com/forums/showpost.php?p=4278790&postcount=60 https://legacygt.com/forums/showpost.php?p=4643620&postcount=117 https://legacygt.com/forums/showpost.php?p=5339079&postcount=188 Thanks so much, soldering I can handle and if that's all it is I'm going to be so happy, the money can be better used elsewhere in the car. Link to comment Share on other sites More sharing options...
