waltzy44 Posted July 9, 2020 Share Posted July 9, 2020 Recently replaced a majority of the front suspension on my new-to-me 06 LGT(Control arms, knuckles, hubs, ball joints, axles, tie rods) and brake pads/rotors, after re-assembly, I've got the ABS & Check Engine Light on and Cruise Control Light blinking, with 'Err 55 (SS)' on the odometer. Using the built-in code reader, shows the following codes: P0500 - Generic Speed Sensor code C0108 - Front Left wheel speed sensor C0107 - Front Right wheel speed sensor C0115 - ABS Sensor I assumed I must've been careless and cracked/ruined the speed sensors, so I went ahead and replaced them both, reset codes and went for a ~15km drive to see if they would re-learn and go away, lights still on. The only two things I can think of that could be the issue: 1. Magnetic rings on both hubs are bad (what are the chances) 2. The non-OE knuckles I used were from a later model Crosstrek/Impreza/Forester/WRX, my few measurements/comparisons side-by-side with OEM seemed to match perfectly, but maybe the spacing on the speed sensors is different, as well as a forum post I saw previously said they were interchangable. Any advice on how to troubleshoot further or next steps? I just want to drive my new project with no problems for the first time! Link to comment Share on other sites More sharing options...
waltzy44 Posted July 10, 2020 Author Share Posted July 10, 2020 Well, the little bit more research in the technical forums may have pointed me in the right direction. Sounds like this is a common issue for moog front hubs. Ordered a set of Timken hubs and will update once they’re swapped in. Link to comment Share on other sites More sharing options...
CBRRICH Posted June 1, 2023 Share Posted June 1, 2023 How did you reset your ABS codes? Did you have a separate scanner or is there a way to do this using the white connetor in the fuse box and the odometer? Link to comment Share on other sites More sharing options...
