BrandonspecB Posted June 15, 2020 Share Posted June 15, 2020 (edited) Made a few changes to my setup and have some things for sale. PM me for payment info. Defroster vent dual 52mm gauge holder: $50 shipped. I've had this for quite awhile. Has a few holes drilled here and there for a few different things I've done over the years. AEM X-series 52mm oil pressure gauge: SOLD 150 psi. Wiring cut and spliced to extend the harness. Has 5v out for datalogging. AEM X-series 52mm oil temp gauge: SOLD Wiring cut and spliced to extend the harness. New sensor. Forgot the original sensor was in the oil pan and cleaned it in the parts washer. 5v out for logging. Prosport Supreme series 52mm boost gauge: $50 shipped Works fine. 45 psi. Only issue is one of the connectors on the back wouldn't stay in, so I gave it a small dab of super glue to keep it in place. STI fuel pump controller: $50 shipped This will get you more voltage to the fuel pump while keeping the factory PWM control. Has 12g wire soldered right to the terminal. Info from this thread: https://legacygt.com/forums/showthread.php/fuel-pump-control-module-143860.html Edited June 16, 2020 by BrandonspecB Link to comment Share on other sites More sharing options...
