STIKILLER01 Posted May 23, 2020 Share Posted May 23, 2020 I just replaced the clutch and transmission on my LGT 05 about a week ago. Has about 150 miles on all the new parts. I just noticed a squeaking noise coming from the trans. I couldn’t tell if it goes away while the clutch pedal is in or out but it only happens at idle. I haven’t found any useful threads that relate to what I’m seeing so thought I’d make my own. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Dalee1104 Posted May 23, 2020 Share Posted May 23, 2020 Sounds like the throwout bearing to me. My brother has this issue in his bugeye but it's really bad. Squeaks a ton at idle, is fine while driving with the clutch engaged, and also goes away if you simply press the clutch in. While idling in neutral the thing is nice a squeaky though Link to comment Share on other sites More sharing options...
STIKILLER01 Posted May 23, 2020 Author Share Posted May 23, 2020 Sounds like the throwout bearing to me. My brother has this issue in his bugeye but it's really bad. Squeaks a ton at idle, is fine while driving with the clutch engaged, and also goes away if you simply press the clutch in. While idling in neutral the thing is nice a squeaky though That’s mainly what I’ve found with research. Still seems weird that it’s a brand new TOB, fork, spring, and pivot stud with 150 miles on it. It’s a exedy stage 1 kit but I broke the pins on the TOB that came with it so I got a new OEM bearing and OEM fork. Could it be a part of the break in period? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Dalee1104 Posted May 23, 2020 Share Posted May 23, 2020 Sadly I have never really heard of a wear in period for those guys. It sounds like that may be the issue but as to why I'm not entirely sure. Somebody else might chime in with some more insight but yeah I'd be guessing something is up with that bearing Link to comment Share on other sites More sharing options...
