shsh0709 Posted May 10, 2020 Share Posted May 10, 2020 Hi all I have just recently discovered that the broken window gusset is the source of a massive water leak from the driver's door. However, when I tried to look for the part, it seems that both left(62320AC010) and right(62320AC000) are discontinued. Is there a possiblity repair without replacement? Thanks a lot. Link to comment Share on other sites More sharing options...
Senseless1 Posted May 10, 2020 Share Posted May 10, 2020 There's always a way. You might want to look up you local junkyard and see if you can source the part there or you can use any number of liquid adhesive sealants as a last resort. I would use something like rtv silicone for waterproofing that needed some adhesion strength. I would switch to epoxy for a permanent bond if it were a structural part that needed more strength than rtv will give. I broke my own sideview mirror, so I guess I'm in the same boat as you. Do you need one or both and do you have a photo of the part Google images isn't that helpful Link to comment Share on other sites More sharing options...
doublechaz Posted May 11, 2020 Share Posted May 11, 2020 I did a little reconditioning work on the rubber gasket parts between the front and back doors on mine using RTV, my finger, and some spit. Came out great as long as you overlook the slight color difference. Link to comment Share on other sites More sharing options...
Senseless1 Posted May 11, 2020 Share Posted May 11, 2020 I'm going to apologize in advance but the guy from the commercial just yelled flex seal in my head. I've never tried it though. Link to comment Share on other sites More sharing options...
Senseless1 Posted May 14, 2020 Share Posted May 14, 2020 If you still need one I just grabbed one from the yard I may or may not need.i broke my mirror but the gusset might be fine. I'll know by this evening. Link to comment Share on other sites More sharing options...
shsh0709 Posted May 15, 2020 Author Share Posted May 15, 2020 If you still need one I just grabbed one from the yard I may or may not need.i broke my mirror but the gusset might be fine. I'll know by this evening. Sorry for the late reply. Is that for the left window? Link to comment Share on other sites More sharing options...
Senseless1 Posted May 16, 2020 Share Posted May 16, 2020 Yes left/driver's side front window gusset Link to comment Share on other sites More sharing options...
