klaus Posted November 22, 2005 Share Posted November 22, 2005 Hi, Our factory NAV is based on Kenwood KNA-DV3200 http://www.kenwood.be/kenwood/kenprod.nsf/_/6A4D691CAF9C953001256D03002FAF18. This system has tons of functionality that depend on a head unit used - does anybody know which one is used in the Subies? From another web site: Touch Panel Control with New Smooth GUI, Selectable GUI Background Wallpaper, Multifunction Key Operation, DVD Disc Menu Direct Touch Operation (Highlight Control Mode), Audio Easy Control Mode, DSI & Security Code, Selectable Key Illumination (Green/Red), New Amplifier Control System with '04 PS Amplifiers - EQ(Bass/Treble/Q Factor/Gain Control) & Voltage/Current/Temperature/Fan Speed Display, Advanced B.M.S.(Bass Management System) with '02 PS Amplifiers, Kenwood KVT-827DVD is TV Ready with Optional TV Tuner Unit (Kenwood KTC-V500E), iPod Connection with Optional Interface Kit (Kenwood KCA-iP500), DAB Ready with Optional Unit (Kenwood KTC-9090DAB), OEM Wired Remote Output, 2-way Telephone/Navigation Mute, Digital Clock (24H), Remote Control Unit Supplied, Maximum Output Power : 50W x 4 (MOSFET Power IC), Gold Plated 4 Preouts with 5V Pre-output Level (Front/ Rear/ Centre/ Subwoofer), 1 RCA AV Output (PAL or NTSC according to the source), 2 RCA AV Inputs (PAL/NTSC Automatic Selection), 1 RCA Video Input with Mirror Mode function for Rear View Camera, Video Input Signal Automatic Detection Mode (Normal/ AUTO), RGB Input for Kenwood Navigation System, Dolby Digital/ dts/ MPEG/ Linear PCM Decode, Dolby Pro Logic II (for 2ch Source to 5.1ch surround), SRS Circle Surround Automotive Decode, 4 Band Parametric EQ/ Digital X'over/Digital Time Alignment, Sound Management System (Type of Car & Speaker Size for Each Channel Selectable), DRC (Dynamic Range Control : Wide/ Normal/ Midnight), Dual Zone Source & Volume Control, Attenuator(-20dB) with Smooth Volume Return, Installer & Backup Memory (Store & Backup Audio & Video Settings), FM/MW/LW 24 Station Presets (18FM, 6MW & LW), RDS with Radio Text, K3i Clear Reception Tuner Circuit, AME (Automatic Memory Entry), Up/Down Seek Tuning, Local Seek, FM Stereo/Mono Selector, DVD Video Playback, DVD±R/RW Compatible (Video Format Only), VCD Compatible, WMA (Windows Media Audio) & MP3 Decoder with ID-3 Tag Display, MPEG 1/2 Video File (.mpg) & JPEG File (.jpg) Playback, 24-Bit D/A Converter, CD Text Ready, CD-R/CD-RW Compatible, Direct Access with Remote, Random/Repeat/Scan Play. A million dollar question - how do we enable some of these features? Any hacks around that we could try? TV-ready? I wouldn't mind watching DVDs on it at least ... Hey, it even mentions iPod connection... Link to comment Share on other sites More sharing options...
t-type86 Posted January 4, 2007 Share Posted January 4, 2007 bump for this being a silly new spec.b owner Link to comment Share on other sites More sharing options...
fatbastard Posted January 4, 2007 Share Posted January 4, 2007 I didn't follow this thread but you might want to look in here: http://www.legacygt.com/forums/showthread.php?t=36342 Link to comment Share on other sites More sharing options...
t-type86 Posted January 7, 2007 Share Posted January 7, 2007 PERFECT!! TY I couldnt find something like that with the search I was doing. Link to comment Share on other sites More sharing options...
