markc0220k Posted February 15, 2020 Share Posted February 15, 2020 (edited) i'm in a middle of changing the shifter joint (shift link?), and meantime getting my radio removed (to install a grom for listening mp3 later). then i found this pink socket has nothing to attach, but the gray socket rite nxt to it is attached to the black wire that goes to the back of the radio .. does anyone know what is it for? Edited February 15, 2020 by markc0220k Link to comment Share on other sites More sharing options...
apexi Posted February 15, 2020 Share Posted February 15, 2020 (edited) I think the pink is satellite radio. Other grey connector is AM/FM antenna? https://legacygt.com/forums/showthread.php/factory-am-fm-sat-antenna-connectors-below-oem-head-unit-229046.html?t=229046 Edited February 15, 2020 by apexi Link to comment Share on other sites More sharing options...
Infosecdad Posted February 15, 2020 Share Posted February 15, 2020 I think the pink is satellite radio. Other grey connector is AM/FM antenna? https://legacygt.com/forums/showthread.php/factory-am-fm-sat-antenna-connectors-below-oem-head-unit-229046.html?t=229046 Yes, correct on both accounts. Link to comment Share on other sites More sharing options...
markc0220k Posted February 15, 2020 Author Share Posted February 15, 2020 (edited) oh ..tht makes sense... reason i asked was because long time (8yrs?) ago i went back to dealer and see if they could install satellite radio for me. they said i dont have preinstall radio and anntena.. so im little surprised tht i actually have the anntena .. thanks infosecdad and apexi Edited February 15, 2020 by markc0220k Link to comment Share on other sites More sharing options...
Max Capacity Posted February 15, 2020 Share Posted February 15, 2020 When I bought my 09 in March 2011, used, I ordered the kit from the dealership for the satellite radio. installed in a couple hours or less, been working great every since. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted February 15, 2020 Share Posted February 15, 2020 https://parts.subaruonlineparts.com/oem-parts/subaru-satellite-radio-sirius-h621sxa101 that's odd, I thought I paid like $64.00 it back then... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 (edited) Yes, correct on both accounts. ok, the pink socket is supposed to connect to an anntena? or satellite receiver? (thanks SVXdc, in his pic he mention the male fakra sat radio - preinstalled cable for accessory windshield anntena) coz i have a after market hd radio (not satellite radio) that anntena-input look like male and exact the same as the pink socket, if the pink plug is wired to built-in anntena somewhere in my car, meaning i'll need to buy a female-to-female cable to connect the pink plug and the hd radio. thanks Edited February 16, 2020 by markc0220k Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 (edited) https://parts.subaruonlineparts.com/oem-parts/subaru-satellite-radio-sirius-h621sxa101 that's odd, I thought I paid like $64.00 it back then... thanks Max, does it mean you just pnp your sirius to the pink socket? i need to confirm that the pink socket is wired to a preinstall-antenna or radio ..thanks Edited February 16, 2020 by markc0220k Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 (edited) ok, i found someone has oem satelittle installed (thanks for the walkthru, Zeta30) . look like somewhere in the car already has an Sat antenna pre installed.. Edited February 16, 2020 by markc0220k Link to comment Share on other sites More sharing options...
Infosecdad Posted February 16, 2020 Share Posted February 16, 2020 Have you seen a small antenna box somewhere yet? On the upper corner of the windshield or back window? Mine is a magnetic aftermarket, so it's on the center rear of the roof, right by the hatch. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 16, 2020 Share Posted February 16, 2020 FWTW, I stuck the black antenna up at the top of the windshield behind the mirror. The kit does not effect the AM/FM antenna. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 Have you seen a small antenna box somewhere yet? On the upper corner of the windshield or back window? Mine is a magnetic aftermarket, so it's on the center rear of the roof, right by the hatch. no, but one section i'm so afraid to uncover is the dom light. would that possible the black box be hidded there? Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 FWTW, I stuck the black antenna up at the top of the windshield behind the mirror. The kit does not effect the AM/FM antenna. not this tiny cover rite? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 16, 2020 Share Posted February 16, 2020 No it's actually pretty big, about the size of the square easy pass. I did check a few minutes ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted February 16, 2020 Share Posted February 16, 2020 Found this, not sure it helps. https://legacygt.com/forums/showthread.php/oem-satellite-radio-install-100102.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 btw, is it possible that navigation antenna and satellite radio both share an single antenna (amplifier?) ? i could only found that antenna locates on top of the dashboard in wrx. In Outback, it's on the roof of the trunk section. Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 (edited) Found this, not sure it helps. https://legacygt.com/forums/showthread.php/oem-satellite-radio-install-100102.html Thanks for searching for me, i also read this walkthru last nite, but one thing i'm still confused is.. 1. i understand the part "plug the wire that came with your reciever into that (the pink socket?) " , but then "and the other end in to the Satellite receiver" ?? Edited February 16, 2020 by markc0220k Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 oh, is it what he means?? (sorry, stole his pic.. ) Link to comment Share on other sites More sharing options...
markc0220k Posted February 16, 2020 Author Share Posted February 16, 2020 If so, all i need is a fakra female-to-female cable like this one, right? Link to comment Share on other sites More sharing options...
