Subinewbie3 Posted December 31, 2019 Share Posted December 31, 2019 So I have heard rumors that 3rd gen struts will fit in my 05 LGT and they have a little stiffer valving. Is this true and are the front and rear stiffer? My plan is to install tein h tech with new struts and not breaking the bank (daily/ winter beater). Would front and rear 3rd gen struts with h techs be a good setup? Link to comment Share on other sites More sharing options...
Nonamedude Posted December 31, 2019 Share Posted December 31, 2019 I think this is only the case on the wagons. In the wagons, the 3rd Gen struts are... better. No one is exactly sure (that I know of) what exactly is different. Something with the rebound and compression. The fronts I believe are more similar than the rear. 2005-2009 Outback Suspension FAQ https://r.tapatalk.com/shareLink/topic?share_fid=90850&share_tid=28368&url=https%3A%2F%2Fwww%2Esubaruoutback%2Eorg%2Findex%2Ephp%3Fthreads%2F2005-2009-Outback-Suspension-FAQ%2E28368%2F&share_type=t&link_source=app I can't comment on spring compatibility between generations or if it's a good set up. But there's some info for you. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
whitetiger Posted December 31, 2019 Share Posted December 31, 2019 no OE strut is good enough for an aftermarket spring, and since the 4th gen has aftermarket konis and bilstein shocks available for its platform, why bother with 3rd gen shocks? even the KYB-GR2s the are available will probably be better than an OE shock(though i would still not put crappy tein lowering springs on them). Link to comment Share on other sites More sharing options...
Subinewbie3 Posted December 31, 2019 Author Share Posted December 31, 2019 My plan was new 04 kyb's but I'm just trying to confirm that the 3rd gen struts are a little stiffer, sounds like it's a maybe. What springs do you suggest then that would only give me about an inch of drop without breaking the bank on a daily? Link to comment Share on other sites More sharing options...
whitetiger Posted December 31, 2019 Share Posted December 31, 2019 1. IIRC the front struts are not compatible, only the rears work. 2. i would not lower the car at all on OE struts, or any other strut for that matter that was not designed for increased spring rates or limited suspension travel. 3. this fixation with using 3rd gen struts is unwarranted if you are buying new aftermarket units. just buy KYBs listed for the 4th gen. Link to comment Share on other sites More sharing options...
Nonamedude Posted December 31, 2019 Share Posted December 31, 2019 I'd imagine you could get some bilsteins. Either get some jdm units (some used for sale in the marketplace right now) or I think the hd8 series is designed for lowering springs. Or get some bc racing coil overs. Those are the ones I know off the top of my head made for most vehicles. What's breaking the bank for you? I mean I just put like 10k into my engine rebuild so $1k on new coilovers doesn't seem that much. I'm looking at 3rd Gen rear kyb, king overload springs, 4th Gen kyb fronts and maybe up rated springs there too. That's about $800 plus assembly labor. If I use the stock springs up front it's still $600. Or get some lightly used jdm bilsteins (not sure about how much they lower) for about $500 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KRM Posted January 1, 2020 Share Posted January 1, 2020 For the reason to lower your car (I'm assuming) is for the looks/style? Don't end up like so many other people who went cheap as possible to only popping the oem replacement struts and end up spending more later. I am really happy with the bilstein struts in combo with the swift springs on my sedan. Like the others have said, using the correct application will get you more enjoyment out of the ride. Not to mention also the safety Link to comment Share on other sites More sharing options...
Andy_Mac Posted January 2, 2020 Share Posted January 2, 2020 Fronts also work if you have a compatible top hat to swap over. Most JDM Bilsteins are thrashed too so you end up being lucky to get 20-30k km out of them. They're usually swapped out because they're starting to get a touch knocky. Well worth getting a properly designed product for the situation. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
Subinewbie3 Posted January 2, 2020 Author Share Posted January 2, 2020 (edited) Would a used set of jdm spec b Bilstein struts with the springs lower the car at all? Also, what exactly blows out the factory struts with the tein h techs? Bottoming out or the spring rate change? Edited January 2, 2020 by Subinewbie3 Link to comment Share on other sites More sharing options...
Andy_Mac Posted January 2, 2020 Share Posted January 2, 2020 (edited) Don't think they lower it much if at all. Ride height looks similar on US ones to JDM ones. JDM pink springs are a good choice for a mild 15mm-ish drop on JDM struts but are expensive for the limited drop you get. The valving just isn't designed for the higher spring rate and limited travel which in most cases causes them to ride quite poorly. It isn't a uniquely Tein spring issue but an issue with almost all lowering springs in general on the factory struts. You can pull them apart and regrease the internals which can help a heap but isn't a long term fix. Edited January 2, 2020 by Andy_Mac 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
Nuclear Posted January 2, 2020 Share Posted January 2, 2020 With all due respect, I sincerely cannot understand why to use both original factory springs (any generation) and second-hand Japanese (Bilstein). There is a long-established manufacturer of quality American springs. https://www.rallitek.com/ These springs behave perfectly with shock absorbers for the previous generation ща Legacy/Outback (in B12 body) Link to comment Share on other sites More sharing options...
Nuclear Posted January 2, 2020 Share Posted January 2, 2020 2005-2009 Outback Suspension FAQ https://r.tapatalk.com/shareLink/topic? Thanks! I forgot about the original source of information - a wonderful squeeze made in 2010. She fully confirms the validity of my words. Link to comment Share on other sites More sharing options...
Subinewbie3 Posted January 2, 2020 Author Share Posted January 2, 2020 Thanks for everyone's help. I think I'm going to go with the koni cut and guts for struts and undecided on the springs still. Link to comment Share on other sites More sharing options...
