Ares3985 Posted December 23, 2019 Share Posted December 23, 2019 So my car has been running at 0 at learning 1 for a while. It idles are 0 and drives at 0. All of a sudden it is going up to -10 but when I drive it goes to 0. I checked for leaks via smoke test and boost leak tester and got nothing. It actually held the boost leak test better than ever before. My wife band is reading 15.6-15.9 at idle which would suggest its lean at idle. Being lean at idle I’ve read isn’t a bad thing because the engine isn’t under any load but why is my accessport all of a sudden reading weird. The afr on the wideband is the same it’s been since my tune Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
