jaylew Posted December 13, 2019 Share Posted December 13, 2019 (edited) So today I go to start my car, and the trip computer is not working, nor is the A/C and stereo interface...the CEL is on. Pull code P0691. After turning the car off, then back on everything worked normal. Engine ran fine the whole time I did throw the A/C belt a month or so ago because of back harmonic balancer and it did wear through the compressor connector. I have replaced the harness to the connector but I am not sure if that could be my issue for this... any suggestions? I plan to check the relay but do you think I should replace it just in case? Edit: Tomorrow I will check the proper operation of the fan circuit according to the recall here. I am hoping that it isn't worst case of bad ECU...I don't know if the relay has been replaced but I figured that the car has made it thus far and it had to have been done. Edited December 13, 2019 by jaylew Wagon is LIFE! - 264,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
jaylew Posted December 13, 2019 Author Share Posted December 13, 2019 So I start up the car today (cold start) but this time I have the hood popped to monitor the fans....nothing. The car is operating as it should fans aren't running. I might get a new relay just as cheap insurance cause whats a few bucks vs a new ECU....that scares me...I'll do it if the ECU ever gets toast, but I don't want to have to Wagon is LIFE! - 264,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
