Ordievet Posted October 25, 2019 Share Posted October 25, 2019 On a 2013 legacy where are the oil pressure sensors located at? I need to change them. Link to comment Share on other sites More sharing options...
DrD123 Posted October 25, 2019 Share Posted October 25, 2019 Assuming this is for the 2.5i, front of the engine on the timing chain cover just under the oil filter (the lower of the two - the other sensor is the oil temperature sensor) Link to comment Share on other sites More sharing options...
Ordievet Posted October 26, 2019 Author Share Posted October 26, 2019 Thanks yeah the temp sensor I don’t need to replace I appreciate the feed back. I’ve been looking online for a drawing or a break down and no luck. I even called the local Subaru dealer and the parts guy was useless. Link to comment Share on other sites More sharing options...
Alexmed2002 Posted October 26, 2019 Share Posted October 26, 2019 Assuming this is for the 2.5i, front of the engine on the timing chain cover just under the oil filter (the lower of the two - the other sensor is the oil temperature sensor) So the 2.5i has a timing chain? I was under the assumption that it had a rubber timing belt... Link to comment Share on other sites More sharing options...
DrD123 Posted October 26, 2019 Share Posted October 26, 2019 So the 2.5i has a timing chain? I was under the assumption that it had a rubber timing belt... up through 2012, the 2.5i had a SOHC EJ25 engine in it, so that comes with a timing belt. In 2013, it got the FB25 engine, which has a chain. Pop your hood and look at the engine! (if you have the oil filter up top, you have the FB25, which has a chain) Link to comment Share on other sites More sharing options...
DrD123 Posted October 26, 2019 Share Posted October 26, 2019 Thanks yeah the temp sensor I don’t need to replace I appreciate the feed back. I’ve been looking online for a drawing or a break down and no luck. I even called the local Subaru dealer and the parts guy was useless. for parts, to identify the part number, I like parts.subaru.com (most online retailers seem to use the same database, too) For more information, this post might be of interest https://legacygt.com/forums/showpost.php?p=5703332&postcount=402 Link to comment Share on other sites More sharing options...
Alexmed2002 Posted October 26, 2019 Share Posted October 26, 2019 up through 2012, the 2.5i had a SOHC EJ25 engine in it, so that comes with a timing belt. In 2013, it got the FB25 engine, which has a chain. Pop your hood and look at the engine! (if you have the oil filter up top, you have the FB25, which has a chain) Wow I never realized this... that saves me worrying about a rubber timing belt from blowing up! Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 26, 2019 Share Posted October 26, 2019 ^ yeah, instead you get to worry about timing cover leaks and chain slap when first starting the car due to hydraulic tensioner failure... I am at 68K and I got a leaker on my 2014 Link to comment Share on other sites More sharing options...
