finnfox Posted October 9, 2019 Share Posted October 9, 2019 Greetings from Finland. And firstly, sorry for my possibly bad english in some points. I have kinda strange problem with my Legacy's Keyless Entry. My key fob has a connection to the car... but doesnt open or close doors. Central locking works fine when opened manually with key or using the "code" with the door handle. So now to the problem-> I noticed the problem when i had closed my doors with the key fob and after 3 hours from that, the key fob didnt do anything anymore. Thought about battery, but no, it wasnt that. Well, then i tried to disconnect the car's battery for a little moment and... The keyless entry works. But it lasts for just one press of either button from the key fob, close or open. Then it wouldnt work anymore. I tried that again and same thing happened. It works just once and then goes full silent. Well, then i tried to re-program the key, but nothing happened. It looks like when i try to program the key (with the white-wires connected), the key fob doesnt do anything. After that i just sat to the drivers seat, closed the doors from inside and started press the "open"-button from the key fob, continiously. Just hoping it would do something. And it actually did, but i dont know what. After pressing the button for 23-times (Doors locked, didnt work with doors open), Legacy gave me a beep and flashed all blinkers/turn signals. It did this now with every press from either button from the keyfob -> Gave a beep and flashed all the blinkers. I didnt understand what it was doing, didnt find anything from internet, so i decided to open the doors. Immediately it started continuous beep-sound, with all the blinkers powered on also. That lasted for 10-seconds. Does anyone have any clue what is happening? Some component possibly gone bad or something else? I also took a video from this, which maybe explains this problem little more. Link to comment Share on other sites More sharing options...
finnfox Posted October 10, 2019 Author Share Posted October 10, 2019 (edited) And if someone knows location for the keyless entry module or possible fuses/relays and would share that info, i would appreciate that very much. Edited October 10, 2019 by finnfox Link to comment Share on other sites More sharing options...
