abakja1 Posted September 7, 2019 Share Posted September 7, 2019 (edited) I have a 2011 lgt and getting ready for a protune at the end of the month. Im about to put on an Invidia catted jpipe to bolt up to the q300 catback i have on now. Do i take out the restrictor pill for stage 2 or leave it in for ots stage 2 map until protune? Threads for 15+ WRXs state to remove pill after jpipe install per Cobb website for the AP, but there are no notes to do this for the LGT. I have a grimmspeed 3 port to go on the day before the day of the tune, but until then ill be on the oem boost solenoid and ots stage 2 map. Any input appreciated. Edited September 7, 2019 by abakja1 Link to comment Share on other sites More sharing options...
Fabsx Posted September 7, 2019 Share Posted September 7, 2019 If the notes doesn’t state anything about removal, don’t worry about it then. If your going 3port, you’ll get rid of it anyways with that install. When I was stage two ots map, I never touched the boost components. When I went for a protune and 3port, that’s when I removed it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
