thomas1657615996 Posted August 20, 2019 Share Posted August 20, 2019 Hi all I have bought a 2005 2.0R Legacy Wagon which has done approx 140k miles. The suspension is stock and can do with an overhaul, but am not sure what to go for. Important: - I can not use saggy but spacers (illegal in Belgium) - I don't want to use non-OEM lowering springs (no illegal, just a lot of hassle) So, these were the options I'm considering: - Bilstein B6 with OEM springs on all 4 corners - Bilstein B8 up front and B6 in the rear with OEM springs on all 4 corners - Bilstein B6 up front with Spec B springs and B6 in the rear with OEM (non spec B ) springs - Bilstein B8 up front with Spec B springs and B6 in the rear with OEM (non spec B ) springs Other options with OEM springs (or KYB springs) and Bilstein or KYB shocks are possible. For reference, a 2.0R wagon has the same weight as a 2.5i wagon you guys have in the US and is 286lbs (130 kgs) LIGHTER than a 3.0 Legacy (I'm sure most of that weight comes from the front-end). Thanks Thomas Link to comment Share on other sites More sharing options...
