NORULZleggy Posted August 13, 2019 Share Posted August 13, 2019 So here is the deal, I searched out for another Subaru after sell my 04 STI, 09 WRX, and many other cars I have had. I am not new to the tuning and parts or Subaru world. I am probably old then most on the boards. So I bout this bone stock 06 LGT from a lady. It is making crazy marble sounds and smoking. I for sure the turbo is gone, but worse it could need a short block. All parts below will go on the motor after the motor is fixed along with dyno tune I am not out to set some power goal, but want to be able to add more in the future. So after talking to many legacy GT people here is what I have so far. Motor parts (EJ257 short if needed, refreshed head, ARPs, Following Maxcaps route): Grimm TMIC kit Grimm EBCS TurboSmart BPV recirc (I really want a bro-off valve lol) AVO induction turbo inlet Mish throttle hose Perrin catless UP Invidia catted DP DW65 pump IDC 1000cc injectors/rails/ P&P harness (top feed con kit) VF52 used (Thinking of just buy BNR18g (they do not need a core) and keeping vf52 for back up, I talked to JMP he needs a core, wish I could just buy one from him) APv3 NGK plugs Timing belt full kit IAG TVG Delete used SPT Intake Killer B pick tube Subaru Gasket set Spec stage 2 clutch and fly ARP head studs 91 and 93 dyno tune Do I need anything else (anything you guys can think of)? 11mm STI oil pump New Oil cooler Link to comment Share on other sites More sharing options...
