olympic Posted August 3, 2019 Share Posted August 3, 2019 Looking for a set of snows for my daughter's 2013 Legacy 2.5i for this winter and have a line on a set of 2009 WRX 8Jx17 ET51 wheels with 235/45R17 snow tires. These should be 5x100 so that part should be fine I just wasn't sure if the 8 inch wheel width would work with the ET51 offset and those 235/45/17 tires on a 5th gen legacy. I tried to search and found references that the bolt pattern would fit but didn't see any references to that larger 8 inch wide wheel and tire combo on a legacy as most info shows 6.5-7.5 inch wide wheel combos that interchange. Might be better to look for a narrower set for winter but would appreciate it if someone can definitely say these will or will not fit. Thank you! Link to comment Share on other sites More sharing options...
FLlegacy Posted August 3, 2019 Share Posted August 3, 2019 Yes they should fit fine. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
dgoodhue Posted August 3, 2019 Share Posted August 3, 2019 They will fit but the tires will look small unless lowered. Link to comment Share on other sites More sharing options...
olympic Posted August 3, 2019 Author Share Posted August 3, 2019 Thanks FLlegacy and dgoodhue for the responses I appreciate it! Link to comment Share on other sites More sharing options...
