thomas1657615996 Posted July 21, 2019 Share Posted July 21, 2019 Hi all I currently have an EUDM Outback 3.0R with SL suspension. The car has done 140 000 miles and would benefit from a suspension overhaul. I would start up front, but want it to be an upgrade. I know I can just order an Outback specifiek Bilstein set from Japan, but chances are it would not meet Belgian laws due to the springs. I was therefore wondering if I could use B6 shocks from Bilstein suited for a Legacy? Not as: yes, they will fit, but more: will it work, will I retain the ride-height etc. Thanks T. Link to comment Share on other sites More sharing options...
lilredwagon Posted August 7, 2019 Share Posted August 7, 2019 I'm not sure about the other markets, but JDM and USDM legacy struts have their lower spring perch at a lower point on the Legacy strut compared to an Outback strut. So you'll lose some ride height from that. Stock Legacy vs Outback springs - I have no idea about stock spring length comparisons. Link to comment Share on other sites More sharing options...
FutureFicus Posted August 9, 2019 Share Posted August 9, 2019 I have LGT Konis with stock Outback springs in the rear and LGT springs up front. https://legacygt.com/forums/showpost.php?p=5912217&postcount=53 Link to comment Share on other sites More sharing options...
Chad W Posted August 19, 2019 Share Posted August 19, 2019 I have LGT Konis with stock Outback springs in the rear and LGT springs up front. https://legacygt.com/forums/showpost.php?p=5912217&postcount=53 Do you have any wheel clearance issues? I'm thinking about LGT struts up front, but concerned that the spring perch won't clear the tires. I'm running 235/50r17 on '11-14' WRX wheels. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 20, 2019 Share Posted August 20, 2019 I know I can just order an Outback specifiek Bilstein set from Japan, but chances are it would not meet Belgian laws due to the springs. Wow, they are going to bug you for putting perhaps better springs?? And how will they be able to tell the difference? The BTS kit will even have the 'subaru outback' sticker on the shock body itself. Link to comment Share on other sites More sharing options...
thomas1657615996 Posted August 21, 2019 Author Share Posted August 21, 2019 Welcome to Belgium. Car-tuning is almost impossible, and springs are seen as tuning. If the springs don't have a certificate that they meet Belgian law (which most lowering or HD springs don't have), your car will fail it's tech inspection. Even more so, your insurance can deny covering you in case of an accident. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 21, 2019 Share Posted August 21, 2019 Yuck!! No thanks. Link to comment Share on other sites More sharing options...
