kred Posted July 6, 2019 Posted July 6, 2019 Here’s a fun puzzle I’m trying to solve: 08 outback 2.5i auto misfiring on cylinders 3 and 4 simultaneously. Only does it under high load when the engine sees over 4500 rpms, otherwise idles and drives flawlessly. Can’t even feel the misfire, my logger just reports 3 and 4 misfire always together with the same misfire count on each cylinder. No other troublecodes. What’s been done after the problem was observed: -complete headgasket job/heads inspected -new coil/wires/plugs -new ecu installed -inspected engine harness pack connector pins Still does the exact same thing under high load. It acts like something electrical since it runs flawlessly otherwise and suddenly 3 and 4 both misfire together. This made me think the coil since 3 and 4 are right next to each other there but replacing it made no difference. Anyone have any other ideas?
RustyRuu Posted July 20, 2019 Posted July 20, 2019 swap your injectors ,3 and 4 are the back injectors, so swap 1 and 2 to where 3 and 4 are an vice versa. if the code comes back or your logger sees the codes move then you found your problem.
