Guest Posted June 30, 2019 Share Posted June 30, 2019 (edited) Some time ago I was asked by a member for a copy of the manual for Bilstein PSS coilovers (BSS-KIT) for 4rd gen LGT. Attached here for whoever may need it.2019_06_30_15_22_55.pdf Edited June 30, 2019 by unclemat Link to comment Share on other sites More sharing options...
utc_pyro Posted July 1, 2019 Share Posted July 1, 2019 Thanks for posting this! It seems Perty generic from google translate, but none the less is helpful. Unfortunately i’m not seeing anything about recommended ride heights or anything. The design of the set is kind of odd, because at least on mine the fronts are drop limited and rears are raise limited. As in I have the fronts all the way down, and rears about 15mm past the helper springs and into fully preloading the main. If you don’t change the rear spring for a longer one you can easily run it out of travel. That just gives an even ride about ~15mm lower than stock. Link to comment Share on other sites More sharing options...
m sprank Posted July 11, 2019 Share Posted July 11, 2019 Bilstein coil instructions are always vague and not necessarily vehicle specific. You tend to get a max and min measurement from the top mount bolt to the bottom.of the spring seat. Link to comment Share on other sites More sharing options...
