jaylew Posted May 23, 2019 Share Posted May 23, 2019 So I thought I just finished up a 6 month project, when an airbag light was present when I first started the car. I took it to a dealership to have the airbag DTC's read, and they are as follows 41 - side airbag RH failure 27 - ODS communication error 42 - side airbag LH failure 36 - seat position sensor LH failure 38 - buckle switch LH failure 29 - ODS failure To give back story I swapped for a black interior. I bought 07 front seats. The ODS (Occupant Detection System), and driver seat belt buckle are from the original tan interior, driver seat position sensor (plugged in but not mounted) The driver seat belt harness is from an 05 junk yard car. At the time of having the codes read, I had junk yard 05, driver and passenger seat airbags plugged in NOT the 07 seat airbags. My thoughts as of right now, the buckle warning is really driver seat belt harness pretensioner. As for the rest I am baffled at the moment. I will be looking into it further, but if anyone knows of any harnesses that somehow involve all of these things and I somehow forgot to plug it in, I am game. I will post any research I find both on the car and off. ** i have all the sensors from the original seats from the car, except for the airbags Wagon is LIFE! - 267,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
jaronervin Posted May 24, 2019 Share Posted May 24, 2019 So I don't know whether or not this can help, but this post seems to solve a problem that I'm having with my airbag light. There's a bunch of information in there that, if nothing else, might help you eliminate potential causes. Good luck! https://legacygt.com/forums/showthread.php/airbag-light-sometimes-console-problemi-149073p10.html Link to comment Share on other sites More sharing options...
jaylew Posted May 28, 2019 Author Share Posted May 28, 2019 Thanks, I will give that a read. I just want to find a way to read the SRS airbag codes outside of going to the dealership so that I know that whatever I do is making a difference or not. If anyone knows a way to read SRS airbag codes let me know, otherwise I am going to try random stuff off amazon Wagon is LIFE! - 267,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
jaylew Posted June 14, 2019 Author Share Posted June 14, 2019 so I fixed the airbag light. Turns out I grenaded the occupant sensor module. Luckily I grabbed a spare last time I was at the junk yard. So I took the 4 strain gauges from the 05 seat, clamped them with hose clamps so as to make the module think a fat person was sitting. Then I plugged in a spare seat belt buckle with spare buckle clicked in so the module would also think that fat person is always buckled up. I then zip tied everything under the 07 seat (tougher than I thought it would be) and called it a day. It makes it so the airbag is always armed for the passenger and no chime. Not the most elegant way but it will work for now. I will now grab a few more modules next time at the junk yard to test more elegant ways. Wagon is LIFE! - 267,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
59ctd Posted June 15, 2019 Share Posted June 15, 2019 An Ancel AD610 should read the SRS codes. This is what I used on my 08 Legacy. Airbag light is on in this car. Codes are: 26 Passenger's Airbag indicator failure 72 Passenger's Airbag failure The passenger airbag was replaced under warranty ~2 yrs ago. Light had been on prior to that replacement. The overhead indicator panel has been replaced twice with known good ones (from my 09 LGT). I am unsure what to check next. Link to comment Share on other sites More sharing options...
