Jadu108 Posted May 13, 2019 Share Posted May 13, 2019 I posted this question in my popping noise thread but i figured it would be easy to miss. So i have no problems freeing the ball joint from the control arm, but i can only get it so far out of the knuckle and no further. Ive seen some people make a tool for that, but that requires access to a drill or drill press, which i dont... I was wondering if a something like the snap on wheel puller set(such as the harborfreight version) would work? Any other suggestions would be nice. Thanks Link to comment Share on other sites More sharing options...
wtdash Posted May 13, 2019 Share Posted May 13, 2019 ...and be CAREFUL. I take no responsibility, blah, blah. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 13, 2019 Share Posted May 13, 2019 I've found that a slide hammer works really well. Using the hub attachment is a little odd since it's only 1 nut instead of 3, but it works the same way. I also use a chisel to spread the knuckle open a little bit but be careful not to go too far or you'll need a new knuckle. Link to comment Share on other sites More sharing options...
Jadu108 Posted May 13, 2019 Author Share Posted May 13, 2019 ...and be CAREFUL. I take no responsibility, blah, blah. Yeah i tried something similar where i got a breaker bar and a long hollow pipe and did that, and then tried to apply more torque, but i was able to only get it so far.. I mean ill try again. But idk My idea now is to afix a wheel puller and maybe that will kinda serve the same way the bolt holes do on the brake rotors? Link to comment Share on other sites More sharing options...
AWDFTW Posted May 13, 2019 Share Posted May 13, 2019 I'm getting myself one of these. I'm sure it'd work better if I had air tools, but work with what ya got... https://www.amazon.com/Astro-Pneumatic-Tool-78620-Subaru/dp/B01JBJFK3C Link to comment Share on other sites More sharing options...
Jadu108 Posted May 13, 2019 Author Share Posted May 13, 2019 I'm getting myself one of these. I'm sure it'd work better if I had air tools, but work with what ya got... https://www.amazon.com/Astro-Pneumatic-Tool-78620-Subaru/dp/B01JBJFK3C Oh that looks rly nice Update i got that mfer out... After jacking the control arm up abd wedging sonething in between that and the knuckle at least 2o timea... I finally was able to get an angle to get a chisel and a hammer and beat down from the top... It sounded like it didnt want to come out... But it did. Cleaned up the inside really well, got all the rust and debris gone and was able to seat the new one in without a problem. Thanks for the input everyone Link to comment Share on other sites More sharing options...
doublechaz Posted May 14, 2019 Share Posted May 14, 2019 You can use sparkplug anti-seize in there to help it come out next time. Link to comment Share on other sites More sharing options...
zzzz Posted May 14, 2019 Share Posted May 14, 2019 I also use a chisel to spread the knuckle open a little bit but be careful not to go too far or you'll need a new knuckle. Chisel, big hammer, and a pry bar works for Turbo Yoda: 6:34 Link to comment Share on other sites More sharing options...
SLW-SVT Posted May 19, 2019 Share Posted May 19, 2019 I'm in the process of doing mine. The driver side took a ton of work. I bought a 3' crowbar and two pickle forks. I was able to get the top part out by prying on the control arm and had to use a ball joint press to get it out of the LCA. The passenger side came out no problem with the crowbar and a pickle fork on the LCA side. Link to comment Share on other sites More sharing options...
Senseless1 Posted March 16, 2020 Share Posted March 16, 2020 I'm shocked nobody has mentioned the company 23 ball joint removal tool yet. Check it out. Link to comment Share on other sites More sharing options...
