amuse_mee Posted May 10, 2019 Share Posted May 10, 2019 I'm About 2k into the most recent oil change, in regards to the H6 engine, are they known to burn through oil? I don’t have any visible leaks, seepage or burning smell. Checked it this morning just randomly and the dipstick measured oil at slightly above the low point. Car was leveled on the street. I just wanted to know if these engines are normally like this. Only twice has the light ever marked me with low oil and immediately I pulled over and added a quart due to it being around the 5k. Just recently had the CVT transmission oil pump resealed due to it leaking. Is this common for other owners? Link to comment Share on other sites More sharing options...
Grnlantern1 Posted May 10, 2019 Share Posted May 10, 2019 I'm About 2k into the most recent oil change, in regards to the H6 engine, are they known to burn through oil? I don’t have any visible leaks, seepage or burning smell. Checked it this morning just randomly and the dipstick measured oil at slightly above the low point. Car was leveled on the street. I just wanted to know if these engines are normally like this. Only twice has the light ever marked me with low oil and immediately I pulled over and added a quart due to it being around the 5k. Just recently had the CVT transmission oil pump resealed due to it leaking. Is this common for other owners?So many opinions on this.. Some say they never lose a drop between changes others say they do.. My case I bought my 15' brand new change my synthetic oil regularly at the dealer on a 5k interval and notice between 500 and 1k miles before the 5k mark I might be close to the Low Line.. I really don't drive hard but mostly freeway miles and I'm at 110k... Hope this helps answer your question.. Just check it regularly when its stone cold..[emoji120] Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Yoda_One Posted May 10, 2019 Share Posted May 10, 2019 I never had any oil consumption on my H-6 or H-4. Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
SubieN8 Posted May 10, 2019 Share Posted May 10, 2019 None for me, however yes Subarus burn some oil. Oil Consumption tests are completed all the time, so maybe ask your dealership to do one and see what they find. Link to comment Share on other sites More sharing options...
Norskie Posted May 10, 2019 Share Posted May 10, 2019 Our 2005 Outback XT went through a quart every 1500 miles or so after 130k. Our other subies (2016 and 2017) do not burn oil. But our 2017 Legacy 2.5i seems to vary in how much oil drains to the pain ... even after hours of sitting on the level, some nights it's near the middle, some near the top. I can't say that I've heard of the H6 commonly having oil consumption issues; but a friend with a Tribeca (3.0 H6) did. Turned out to be a cracked head. Link to comment Share on other sites More sharing options...
hkshooter Posted May 11, 2019 Share Posted May 11, 2019 I'm one of those who's H6 doesn't consume any significant oil, yet. Full after change, full before next change. 90k so far. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
Golferdude1087 Posted May 12, 2019 Share Posted May 12, 2019 The h6s will consume, some less than others..mine is very little...some have failed Subaru consumption tests and gotten a new short block The recommended weight by Subaru is 5w30...they don't handle it well and often sheer it to 5w20, Which is where the consumption can come from If you want to try you can use a 5w40 weight full synthetic which the 3.6R motors greatly prefer. Blackstone approves as well I'm running 5w40 n lose maybe 1/2 quart per 5000 miles..i have 143k on my car now Sent from my VS996 using Tapatalk Link to comment Share on other sites More sharing options...
Brisvegas Posted May 12, 2019 Share Posted May 12, 2019 The recommended weight by Subaru is 5w30...they don't handle it well.If you want to try you can use a 5w40 weight full synthetic which the 3.6R motors greatly prefer. I'm not saying you are definitely wrong .... but I am saying that I find it odd that if 3.6R engines "don't handle 5w30 well" and "greatly prefer 5w40" that Subaru engineers would not have also come to that conclusion. It would certainly be in their interest to do so, if that was in fact the case. Link to comment Share on other sites More sharing options...
waldguy Posted May 13, 2019 Share Posted May 13, 2019 So maybe the fact that this poll has disappeared for about 18 months shows that oil consumption in general is not a huge issue -- appears to be about the same with the 3.6 as the 2.5 with that small sample. https://legacygt.com/forums/showthread.php/amount-oil-added-between-changes-238379.html Link to comment Share on other sites More sharing options...
