UziLoogie Posted May 3, 2019 Share Posted May 3, 2019 I have noticed that my legacy struggles to turn over after fueling up, it takes a few key turns and a couple presses of the gas peddle to get things running. My first thoughts would be injector, fuel filter, or evap line. This has happend filling just a little bit and also filling its near limit. Link to comment Share on other sites More sharing options...
epicsockzebra Posted May 3, 2019 Share Posted May 3, 2019 Sounds like an EVAP problem, perhaps a purge valve Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 3, 2019 Share Posted May 3, 2019 Next time you fill up leave the key in the ON position. This will allow the evap to vent when filling up. Also make sure when the pump stops that you don't fill it up anymore. Fuel can leaking into the charcoal canister and get into the vacuum system. Link to comment Share on other sites More sharing options...
