loganbrooks Posted April 13, 2019 Share Posted April 13, 2019 Anyone know if there are any major differences between the EJ20X and EJ20Y model. Apart from the obvious, that the X is coupled with auto transmission, Y with manual. Have an EJ20X engine and looking at installing into a manual transmission legacy, keeping within the 4th Gen legacy for simplicity. Haven’t found much on the web, most information seems to suggest they are the same. Any info would be appreciated, Thanks Link to comment Share on other sites More sharing options...
l88m22vette Posted April 26, 2019 Share Posted April 26, 2019 They're the same, you can definitely use the X with a manual trans. The pre-facelift were more different, where the X had a VF38 vs. the Y with a TD04HLA, but the post-facelift all had VF45. Post-FL also had 3-wire ex. cam sensors and an airpump. The biggest issue is that you need the engine to be the same year as the car so you avoid handling the differences. Look me up on subaruoutback.org, my engine swap thread covers all of it. Link to comment Share on other sites More sharing options...
