Dunrana Posted January 12, 2019 Share Posted January 12, 2019 the shifter dosn't have a very positive feel. also, it seems absurdly easy to miss second, fourth and reverse. is this normal, a preformance part sombody put in (it's been a first car thrice now), or something i need to repair? Link to comment Share on other sites More sharing options...
RustyRuu Posted January 12, 2019 Share Posted January 12, 2019 is the sifter just sloppy like it's not tight when in gears and such? this guy has a DIY fix but mostly i'm just trying to show you what part to look at, driver side of transmission, where the shift shaft from tranny links to the shift linkage. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 14, 2019 Share Posted January 14, 2019 Probably a bad shifter joint. Common problem. Hard to replace in the rust belt if your not handy. OEM Shift Joint https://tinyurl.com/y9a5glem Poly Shift Bushings https://tinyurl.com/ycz8jqkq Video on replacing https://tinyurl.com/yaa2oy5d Link to comment Share on other sites More sharing options...
