4thsubaru Posted January 3, 2019 Share Posted January 3, 2019 Hello All, I believe this was discussed once but I could not find it. Since ETS won't make more or their headers anybody got a crystal ball to see if these may fit? https://www.cntracing.com/collections/2015-subaru-wrx-sti/products/cnt-racing-2015-2018-subaru-wrx-stainless-steel-header or https://www.privatelabelmfg.com/product_p/plm-subaru-header-gk-el.htm Thanks Link to comment Share on other sites More sharing options...
Sarang Posted January 3, 2019 Share Posted January 3, 2019 It is discussed in this thread: https://legacygt.com/forums/showthread.php/vogtland-2004-wrx-lowering-springs-276737.html?t=276737 I don't think we have an answer because no one has tried it (that I know of). Keep in mind that our turbo has a different bolt pattern from the WRX turbo, so at a minimum you would have to either switch turbos or switch the flange. Link to comment Share on other sites More sharing options...
4thsubaru Posted January 4, 2019 Author Share Posted January 4, 2019 It is discussed in this thread: https://legacygt.com/forums/showthread.php/vogtland-2004-wrx-lowering-springs-276737.html?t=276737 I don't think we have an answer because no one has tried it (that I know of). Keep in mind that our turbo has a different bolt pattern from the WRX turbo, so at a minimum you would have to either switch turbos or switch the flange. Thanks, not sure it would be worth it to get someone to hack at that piece, looks like custom is the only avenue at this point Link to comment Share on other sites More sharing options...
