PATS4LIFE Posted December 27, 2018 Share Posted December 27, 2018 Ok as of right now I have 326mm Sti front rotors which has same hub diameter as 6th gen Legacy Which is I believe 58mm. Now my question is would it affect anything if I were to go with a rotors with a larger hub like 68mm? I plan on using a 2005 Volvo s60 R AWD front rotors with 330mm x 32mm 68mm hub hole, and have it re-drilled to a 5x114.3 Thanks everyone.. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 27, 2018 Share Posted December 27, 2018 why? are you looking for better braking? if so, tires first Link to comment Share on other sites More sharing options...
PATS4LIFE Posted December 27, 2018 Author Share Posted December 27, 2018 why? are you looking for better braking? if so, tires first I will be getting tires when my stockers are worn out,and I’ll be switching to 19’s Reason I’m wanting to switch to a 330mm rotors I because I have Cadillac Brembos CTS V calipers right now,and the Sti rotors are a bit smaller(326mm) Which causes the pads to slightly stick out a bit. Link to comment Share on other sites More sharing options...
Grnlantern1 Posted December 27, 2018 Share Posted December 27, 2018 I will be getting tires when my stockers are worn out,and I’ll be switching to 19’s Reason I’m wanting to switch to a 330mm rotors I because I have Cadillac Brembos CTS V calipers right now,and the Sti rotors are a bit smaller(326mm) Which causes the pads to slightly stick out a bit.Why not find the Rotor Size of the Cadillac and see if you can get a 5 x 114.3 Rotor to match. My Rolloface is 356mm.. Sounds like your Brake system is a little unsafe with parts that don't work with each other.. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
PATS4LIFE Posted December 27, 2018 Author Share Posted December 27, 2018 Why not find the Rotor Size of the Cadillac and see if you can get a 5 x 114.3 Rotor to match. My Rolloface is 356mm.. Sounds like your Brake system is a little unsafe with parts that don't work with each other.. Sent from my SM-G965U using Tapatalk Ya I already check Cadillac rotors,the hub hole is a lot larger than the Volvo rotors,the only good on the Cadillac rotors is already 5x114.3 As for the braking system that I have it is fine no issues with it,it’s day and night better than stocks, only reason why I wanna go 330mm rotors is so it can use up the entire pad,I just don’t like the brake pad overhang due to the Sti rotors being a bit small in diameter. Link to comment Share on other sites More sharing options...
beardman Posted December 28, 2018 Share Posted December 28, 2018 I used the v70r 330mm rotors on an old a4 and they were great, very well ventilated. There a guy that you might want to talk to that does custom rotor work. Google adamsrotors. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
