Power steering vibration...
Could be a few things.
- Front Top Mount Bearings
- Outer tie rod ends
- Front axles
- Differential(s)
- Tires
- Power Steering
Does it do it in one direction more than another? Check the P/S fluid too should be a nice red.
When the car is warmed at a stop turn it lock to lock and see if it still vibrates.
  • 1 month later...
Yes. I started with the simplest thing first and changed the power steering fluid (which is dextron 3 transmission fluid). I bought a fluid extractor for $15, and sucked out the reservoir and refilled it about 4 or 5 times. It took about a quart of fluid. The vibration lessened each time I filled it until the last fill when i could no longer detect it. Easy peasy. Edited by dvto2
Great information, I'll give that a try.
